Page 1 of 8 123 ... LastLast
Results 1 to 10 of 77
Thread: Suzuki GSX-750 '99 conversion
    Senior Member ardhout's Avatar
    Apr 2011
    107
    Yesterday I collected my Suzuki GSX-750 '99 bike at the motorbike shop.
    The owner took already the drive train out of the bike so I got it half price.
    Conversion is aimed at light weight and high speed.
    Parts which I'm planning to use:
    - Enertrac MHM-602 motor
    - 48s2p 16Ah Headway cells for 156V
    - 150A/300A 144V controller
    Apr 2011
    107
    My hub-motor arrived quickly in only 3 weeks.
    Junior Member shaunmza's Avatar
    Jan 2011
    Cape Town
    21
    Love the look of that bike.
    Was the motor supplied with those vents in the picture?
    Apr 2011
    107
    Yes, at first thought it was a recent modification but when I looked back at older photo's the vents were there from the beginning.
    Apr 2011
    107
    Electric diagram v1.0
    This is my first version of the electric diagram.
    If there are faults in it or for other advises, please let me know.
    Attachment 1539
    1,794
    Quote Originally Posted by ardhout View Post
    Attachment 1539
    Looks pretty good to me.
    Only thing I noticed is that your DC/DC will always be on (getting input voltage) so whatever idle power it waste may drain your pack if its let to sit too long.
    Doesn't the kelly need 24V or more on the enable pin (pin 1)?
    And yeah, the DC-DC will always be on. What DC-DC are you wanting to use? Maybe it has an enable pin?
    1,794
    Doesn't the kelly need 24V or more on the enable pin (pin 1)?...
    I believe you are correct. He could just run pack voltage to that pin, just get the voltage after the contactor so the controller can be turned on and off.
    Apr 2011
    107
    Specs of the KHB say: 8-30VDC, preferable 24V.
    After asking Kelly further, they assured me that these KHB are also working good with 12V, but they advised me 13.5V because of the little voltage sag, when using full lights, horn etc.
    The DC/DC converter i'm using is the Kelly's HWZ serie, 25 Amps.
    http://kellycontroller.com/hwz-serie...25a-p-536.html
    Apr 2011
    107
    Yes, I'm aware of that. There is a good topic about this, and what I saw is that the idle current is quite low for such converter (didn't measure it though), but I'm going to calculate it.
