Results 1 to 2 of 2
Thread: hydraulic brake fluid disappear on a Z-6 scoote
    99
    Why does the rear hydraulic brake fluid disappear on a Z-6 scooter?
    There is no obvious leakage.
    The front brake doesn't show any reduction.
    Member moparren's Avatar
    Tucson AZ
    62
    Add moparren on Facebook
    Visit moparren's Youtube Channel
    Is it a disk brake? It is normal for the fluid level to drop as the pads wear on any disk system but it shouldn't ever empty the reservior. If that is the case go over the entire system and check every conection and every hose. A small leak can add up over time...
