Results 1 to 2 of 2
Thread: Proper Gearing for ME-1003
    Mar 2012
    Iv'e got my bike road worthy:
    81 KZ440 LTD
    ME-1003 (72V, 200 AMP, 3050 RPM)
    AXE 7245
    6 Sealed Lead Acid 26ma batteries
    30A DC2DC
    Gear ration 10T Front, 45T Rear (stock)
    After some calculations, I see I should do about 50-55 mph top speed
    I can only get up to about 38
    What is the reason I am only getting 2200 RPM out of my motor?
    Poor gear ratio?
    Improper wheel/engine alignment?
    Un-programmed controller? (waiting on the cable)
    Seņor Member podolefsky's Avatar
    Boulder, CO
    Did you get the controller new? Of so, it should be ok...but possible the speed is turned down.
    Other possibilities..
    -batteries aren't charged
    -throttle isn't going full on
    -there's some added load (something rubbing, or going up hill)
    You should probably go to an 11 front...10 is kinda small. That RPM is unloaded...with a load it will be lower.
    - Noah Podolefsky -
    The GSX-E
