First off, these questions are directly for my bicycle light project which will be a 12.8V 3.3Ah 4s1p pack. I am looking to sort out the LSDs (Little ****ty Details) so that as I hopefully one day move on to a bigger project I'm not asking the same numb questions.
So here it is, how do you build a battery pack? Ok, so my old NiMH 5s2p pack has thin flat metal "bars" connecting them, then there was a paper cover over the ends, a bit of saran wrap, and then 2 layers of heat shrink, and maybe some sort of voltage/current protector in there (little white rectangular do-dad in series with the batteries. And the "bars" don't look to be soldered but tapped in in place with a fine point. I'd rather solder something for a greater contact surface. The batteries I am looking at using are basically long C cells (26650).
So what is the best way to connect my batteries? Do I buy or make these nice little flat bars, or is good old wire acceptable? If so, what gauge? I know there is a calculation for this, but I don't remember it. I can also get them with with tabs added for 25 cents a battery. Would that do? I can get those nice square plastic battery holders for these, just like the ones you can get for the headways. How do I wrap these up, or protect them from the elements? I have a nice case that will be sealed, but this light is for my MTB, so better safe then sorry. Also, what kind of voltage/current protector should I use to protect the LiFePo4 batteries? I will use a charger specifically for those, so I am not as concerned about charging as I am worried about excessive discharging from a wire shorting out or something. And, how do you balance batteries that are in series? More importantly, for a max of 18 watts worth of LED draw from LiFePo4 with a charger designed to work with a battery pack that size, do I really need to worry about it?
Also, does anyone know about the Battery space website? Do they sell good stuff?
A gentleman on the MTBR DIY light forum was helpful when choosing LiFePo4 batteries, but suggested I leave soldering a pack to the professionals. I replied, but it would have been better off sending him a resume. Someday I'll grow up. There is also quite a bit on the candlepower forum on bicycle lights. But I have yet to take the time to sign up to ask questions, and I saw nothing on building packs there, at least for bicycle lights.
Thanks,
Rich
