http://www.ecrp.eu/en/ecrp-1-4-the-e...ical-data.html
They claim the bigger pack is 8.9kWh, but if you use the voltage and Ah numbers, my math says the smaller pack is 7.4 as advertised, and the bigger one is 8.7875kWh. Either way, and extra 2+ kWh for just 20kg isn't bad. I wonder how it will stack up, not so much against the Mission, but the Brammo 12.0 RR. The RR seems to be a compromise between the Mission R and the eCRP. I suspect we will find out it is much lighter than the Mission R, but still significantly heavier than the eCRP. But I've been wrong before.
And, does anyone know what motors they are referring too? My guess was they were going to be the new Agni's.
Rich
