Results 1 to 5 of 5
Thread: How to SPAD (Sketchup Photo Aided Design)
    3,889
    I wanted to build off of Ted's excellent PAD thread by describing how to use Sketchup to design a part from a photo.
    First you need a photo. Follow Ted's instructions on getting a good image (he's the photo taking expert). I'm stealing his because it will link the threads nicely (and I'm lazy). Thanks Ted!
    Ted's Photo
    Then go get yourself Sketchup. It's free for "personal projects". What you're getting is Skethup "Make", which has nearly all the functionality of the paid "Pro" version. For commercial use, you should get Pro to adhere to their licensing.
    3,889
    reserved
    3,889
    Once you have Sketchup, play around with it a bit. I describe everything you need to do in the video below, but it doesn't hurt to get your feet wet first.
    In Part 1, I import the photo and scale it. In Part 2 (coming up), I'll do a sanity check, and in Part 3 I draw the motor mount.
    By the way, as Ted said in his PAD thread, having a ruler in the photo can help get the scaling even more precise. I just use a dimension I happen to know, which works well too.
    3,889
    Part 2 - doing a sanity check on my photo and scaling.
    3,889
    Part 3 - drawing the actual motor mount.
    That's it! Hope this was helpful. Questions, comments? Shoot em out there.
